Windows 10 Het Wimwizard alternatief is krachtiger dan NTLite!
kloolk
Nieuw lid
Gevonden op een Duits forum.
Worlds Most Advanced Windows Image Servicing & Customization Tool !
Advanced configuration reduces by 90% OS post config user interaction.
Blazing fast, super stable, secure, simply incredible and the real friend in need.
For both novice & high end users.
Real size friendly...only under 400KB footprint.
Very Powerful build on top of .NET4.8.1 (support beyond 2034).
Extreme Ozempic slim down of WinSxS up to 100mb in size !
Removal of 32bit-wow64 ancient code making the os pure amd64-64bit only.
ESU post November 2025 for Windows 10 SSU + CU offline image updates.
Extreme slim down due of proprietary engine of components removal.
Protection for registry imports and delete (it never touches the live os).
Protection for components removal (only operates inside mount path).
Removal for system very outdated drivers drivers (Via, SiS, Intel Telemetry).
Windows 10, 11 and 12 Compatible (You can create / edit / improve and innovate your own XML's for Components Removal).
and much, much more...
v1.0_build.28-April-2026
Added: New Engine for Components Create and Remove -> so far is singlethreaded but still fast
Improved Files and Folders Clean Up
Readded BACK STRONG protection for Registry removal -> so you can never edit the live registry
Readded BACK STRONG protection for files and dir clean up -> only the mounted image will be used
Improved Compatibility for Depends by and For Create and Removal Engine
Improved Speed and Code Optimization for.NET4.8.1
Improved Parsing/Decoding Components
Refactor wow64-32bit compatibility for people who still use 32bit-wow64 ancient code
Removed: Auto Sense Ai Engine -> hard to maintain it for now
Removed: RAW Engine -> the world's super fastest engine but hdd's can't handle it
Removed: HardLinks
Removed: Over 4000 lines of code
Removed: MultiThreading -> some HDD are too slow to handle the heat, cackle, cackle
Removed: IO Locks for multiple on parralel components removal -> req at least 4 core cpu
Removed: personal system and trusted installer code -> now all is done via external app AdvancedRun
File size: 439.87KB
SHA256: 4cb47637522e3638158bab5b288a312eb155420063bab22bc55fb0bcd3cef58e
en de website https://wimwizard.blogspot.com/p/wimwizard.html
wimWizard gedownload van Github, na unrarren:
de (1) moet uitgevoerd worden powershell admin
na het vervolledigen van: 'source folder', 'output WIM filename' en de andere item komt er onderaan 'RUN' en klik daarop ...
daarna zie je volgende zaken:
de nieuwe install.wim in de gebruikte iso gestoken met anyburn vervolgens getest in vmware.
deze methode heeft me niet echt kunnen overtuigen dat het beter is dan NTLite.
trouwens NTLite is erg uitgebreid, geeft wel een goed resultaat.
wat snel en goed is : autounattended.xml file met volgende file maker:
kan je integreren in je iso, anyburn, of een copy van deze file in je usb-stick.
eens je autounattend.xml file gemaakt is, kan je deze éénvoudig aanpassen aan de 'Home' of 'Pro' versie.
die 'wimWizard' is niet 'mijn' ding ... uitgetest en verticaal geklasseerd!
ieder zijn heug en meug!
inderdaad GEEN crash, openen met de gewone Powershell (1) of Powershell 7 (2):
dit is wel een ander voorbeeld van: ' xxx.ps1 ' , 't is dezelfde werkwijze.
was jij in je active carrière een IT-medewerker? mmm ... ik een simpele telecom-tech.
