Sandboxie Plus
Sandboxie Plus 1.17.2
PhilipV heeft Sandboxie Plus bijgewerkt met een nieuwe update:
versie 1.0.21
Sandboxie Plus 1.0.21 / Classic 5.55.21 fixes:
Added
  • added mini dump creation to Sandman.exe in case it crashes
Changed
  • disabled Chrome and Firefox phishing entries in new sandboxes (by isaak654) #1616
  • updated Mozilla paths for the BlockSoftwareUpdaters template (by isaak654) #1623
  • renamed "Pause Forced Programs Rules" command to "Pause Forcing Programs" (Plus only)
  • reworked tray icon generation now using overlays, added busy overlay...
Lees meer over deze update...
Versie 1.1.3
Added
  • added group first sorting #1922
Changed
  • updated Classic UI Swedish translation (thanks pb1)
  • restored Plus UI Turkish translation #1419 (thanks fmbxnary)
Fixed
  • fixed issue with recovery window on delete #1948
  • fixed double-click issue on path column #1951
  • "AllowBoxedJobs=n" is back to the default behaviour as issues were reported #1954
  • fixed issue with internet block #1955
  • fixed grouping issue in the Plus...
versie 1.2.7
Sandboxie Plus 1.2.7 / Classic 5.57.7 release notes:
This build fixed a couple of issues. If you have issues with an update installation, just uninstall the previous version keeping the sandboxie.ini and reinstall the new build.
Sandboxie Plus 1.2.7 / Classic 5.57.7 changelog:
Added
  • added option to alternate row color in all lists
Changed
  • SandboxieLogon is now disabled by default as it was not compatible with 3rd party antimalware tools...
versie 1.3.1
Added
  • added ability to switch fusion theme independently of the dark theme
  • added ability to download updates from the support page
  • added missing system calls to the hardened box type 88bc06a b775264 04b2377 (thanks Mr.X)
  • added search box to the Plus UI Settings and box option dialogs #2134
  • added Korean translation to the Plus UI #2133 (thanks VenusGirl)
  • added grouping to sandman tray menu #2148
Changed
  • improved info label
  • the look...
versie 1.3.2
Added
  • added icons to sub tabs in the box options dialog
  • recovery and message pop-up menu options are not persisting across UI restarts any more
  • added new box color, a white box indicates that its not really a sandbox and is displayed when the user specified OpenFilePath=* or alike
Changed
  • Sandboxie no longer issues message 1301 when forced processes are temporarily disabled
    -- the message can be...
versie 1.3.3
Sandboxie Plus 1.3.3 / Classic 5.58.3 changelog:
Added
  • added domain\user notation when the LogFile registry setting is applied as workaround for #2207
    -- usage: in "HKLM\SYSTEM\CurrentControlSet\Services\SbieSvc" add REG_SZ "LogFile" with "3;[path]\Sandboxie.log"
  • added option to block host processes from accessing sandboxed ones #2132
    -- usage: DenyHostAccess=Program.exe,y
    -- note: by default, this protection only applies for write access, that is, unsandboxed processes...
versie 1.5.1
Added
  • added SBIE2227 warning when a sandbox is located on a volume without 8.3 name support
  • added template for Tencent QQ #2367
Fixed
  • fixed issues when renaming a sandbox with a custom path #2368
  • properly fixed the Firefox 106 issue 46e9979
  • fixed issue with alternative UI modes #2380
  • fixed command line corruption with breakout processes #2377
  • fixed issues with Privacy Enhanced box types #2342
  • fixed issue with boxed object directory...
versie 1.6.4
Sandboxie 1.6.4 Plus / Classic 5.61.4 changelog:
Added
  • added option to disable sandbox clean-up on startup #2553
  • added contribution guidelines in the Help menu for both Plus and Classic UIs #2551
Fixed
  • fixed issue with auto delete sandbox on SandMan startup #2555
  • fixed issue with Windows 11 context menu when SandMan was not already running #2284
  • fixed issue with the display about cmbDefault #2560 (okrc)
  • fixed issue with color inaccuracy...
versie 1.6.6
Sandboxie 1.6.6 Plus / Classic 5.61.6 changelog:
Changed
  • reworked trace log retrival to greately improving performance
  • improved list/tree finder
  • improved trace logging
  • enabled drop admin rights option for compartment style boxes
  • -- Note: programs started unsandboxed can not have rights dropped, but UAC prompts and elevation from within the sandboxed are blocked
Fixed
  • fixed potential BSOD issue in the driver
  • fixed crash in in trace log...
versie 1.6.7
Sandboxie 1.6.7 Plus / Classic 5.61.7 changelog:
Toegevoegd:
* optie toegevoegd aan de klassieke ui om een supporter certificaat toe te passen
Gewijzigd:
* tijdsgebonden certificaten hebben nu 1 extra maand gratis geldigheid, om de verlengingsduur te verbeteren
Opgelost:
* probleem met Hebreeuwse taal opgelost (klassieke UI) #2608
* probleem met startmenu-integratie en snapshots opgelost
versie 1.7.2
Sandboxie 1.7.2 Plus / Classic 5.62.2 changelog:
Gewijzigd
  1. box opties opnieuw georganiseerd, oude box lay-out is weer standaard
  2. SBIE2227 die aangeeft dat volume zonder 8.3 naamondersteuning nu standaard is uitgeschakeld --Opmerking: u kunt "EnableVerboseChecks=y" gebruiken om deze controle opnieuw in te schakelen
Fixes
  1. vast verwijderen v1/v2 weergave respecteert nu globale voorinstellingen
  2. voorkomen dat de Verkenner wordt geblokkeerd bij het slepen...
versie 1.14.5 Plus
Sandboxie 1.14.5 Plus :
Toegevoegd :
  • hwid-weergave toegevoegd
  • Taalspoof "CustomLCID=1033" #4024 (met dank aan Yeyixiao)
  • optie toegevoegd om de Sandman UI altijd als admin uit te voeren #4090
  • Proxy-uitsluiting toegevoegd #4036
  • "ForceChildren=Program.exe" toegevoegd #4070
  • UI-opties toegevoegd voor "ForceRestartAll" en "UseCreateToken" in OptionWindow
  • een optionele contextmenu-optie toegevoegd om snel mappen/bestanden geforceerd te maken
  • Opmerking: U kunt...
versie 1.15.5
Toegevoegd
HookTrace=y' toegevoegd om API hooking te debuggen
Gewijzigd
  • Gegevensmap Sandboxie-Plus verplaatst van C:\AppData\Lokaal\Sandboxie-Plus naar C:\AppData\Lokaal\Xanasoft\Sandboxie-Plus
  • Opmerking: de map wordt automatisch verplaatst, bij een downgrade naar een oudere versie moet je de map handmatig terugverplaatsen.
  • sommige opties in het contextmenu van de box een beetje opnieuw geordend #4444
