Heb een beetje zoekwerk gedaan voor u en kwam dit tegen !
DiFolders v2.0 (c) DiFolders Software
Supplier : TEAM ViRiLiTY │ Release Date : 24th Apr 2003
│█│ *****er : TEAM ViRiLiTY │ Disks : 01 x 1
.44mb │█│
│█│ Packager : TEAM ViRiLiTY │ Protection : Timelimit │█│
││▓│ Requirements: Windows PC │▓││
│ Release Notes ██▓▓▒▒░░ ░ │
Are you tired of files scattered throughout your hard drives? Do
you want your files to always be found at the right place? If so,
you need DiFolders to be installed on your computer.
You just create your own folder (difolder), set rules for it, and
all files that you put into this folder will be sorted (moved,
copied, deleted, etc.) according to the rules.
DiFolders features include:
Creating multiple difolders and setting any number of rules for it.
Special expressions for rules: file masks for source files, variety
of variables to use in destination files, such actions as move,
move + run, copy, delete files.
MP3 Tags support: You can use an MP3 file tag information for
destination file and folder names.
Multiple hard and removable drives support.
Network support (DiFolders.Network only): You can use your local
area network computer's folders as difolders, for example, to
synchronize files.
File synchronization: You can set rules in such way that your files
will be synchronized with folders on other drives or network
computers.
and a lot of other features...
| Install Notes ██▓▓▒▒░░ ░ |
1. Unzip & Unrar
2. Install
3. Copy "DiFolders.exe" from the /***** folder and copy it t
o the
installed dir and replace the existing file!
Enjoy!
||░│ Applying ██▓▓▒▒░░ ░ │░||
│█│ YOU SEARCH FOR A WELL ESTABLISHED GROUP? │█│
│█│ GET IN CONTACT WITH US NOW IF YOU FIT TO ONE OF THE OPEN │█│
│█│ POSITIONS │█│
│█│ We are looking for: │█│
│█│ - talented *****ers pc ( fast conn would be good ) │█│
│█│ you should be able to handle daily shareware protections │█│
│█│ and keygen them if possible. you may have experience with │█
│█│ commercial protections like hasp... │█│
│█│ - someone who can supply fast, stable shells for legit things │█│
│█│ - software supplyer ( no webware ) │█│
:│█│ - siteops of well established +100mbit sites
|│█│ - somethin else that may help us │█│|
│|▒│ AND KEEP IN MIND THAT JOINING A GROUP TAKES A LOT OF TIME! │▒|│
||░│ Contacting ██▓▓▒▒░░ ░ │░||
│█│ email:
vrl@hushmail.com │█│
│█│ irc: NOT FOR PUBLIC │█│
:│█│ www: NOT FOR PUBLIC │█│:
||░│ Greetings ██▓▓▒▒░░ ░ │░||
│█│ ACME - ARCTiC - BLiZZARD - CORE - CRO - ECLiPSE - LUCiD │█│
│█│ SAC(ESPECiALLY EBOY)- RENEGADE - TMG - UCF │█│
:│█│ and all other ppl who helped us │█│:
|│█│ (not listed due privacy) │█│|
│ NFO by: Eboy^SAC Updated on 2003-02-05 by TEAM
ViRiLiTY │
IF YOU LIKE THE PROGRAM, BUY IT!
WE DOIN THIS FOR FUN!
