Misschien kan je eens - how to unlock ransomware - googelen. Je vindt er een paar suggesties om sommige RW's te unlocken. Wees voorzichtig, want er zijn ook hier onbetrouwbare sites...! Ga alléén naar sites van bekende anti-virus firma's. O.a. van Emsisoft, Kaspersky en anderen.
VB: The RannohDecryptor utility was initially created to decrypt files, which suffered from Rannoh ransomware. In time it acquired additional and useful features. Now it can be used to cure your files from CryptXXX activity.
So if CryptXXX ransomware has found its way into your system, not everything is lost. To recover your files we will need the original (not encrypted) version of at least one file, which suffered from CryptXXX. If you have more files like this backed up, this will work.
Then you need to do the following:
Download the tool and launch it.
Open Settings and choose drive types (removable, network or hard drive) for scanning. Don’t check the “Delete crypted files after decryption” option until you are 100% that decrypted files open properly.
Click the “Start scan” link and choose where the encrypted .crypt file lies (that file, for which you have an unencrypted copy as well).
Then the tool will ask for the original file.
After that RannohDecryptor starts searching for all other files with “.crypt” extension and tries to decrypt all files, which weigh less than your original. The bigger file you’ve feed to the utility — the more files would be decrypted.
WW
