Ace Utilities 4.1.0 Build 4052SYSTEM ToolsAce Utilities
heeft er iemand ervaring met dit programma?
Ace Utilities is an award winning collection of tools to optimize your PC's performance. It allows you to find and remove the junk files in your PC, invalid registry entries, delete your internet usage history, provides plug-in support to erase the usage history for over 200 third-party applications, manage your cookies and much more. With a detailed startup- manager you can see what all programs, services, drivers, etc start automatically with Windows and optionally disable them. Furthermore, Ace Utilities also includes options to find true duplicate files, fix or remove broken shortcuts and to uninstall software completely. Other features include secure file deletion, disk space analysis, an empty-folder finder and more.
Features:
- The most advanced registry cleaner to clean windows registry.
- Clean unneeded junk, temp and obsolete files from your disks using disk cleaner.
